Micron MR603a query
collectors
Was looking to switch a few led’s “5” from a Micron MR603a. It seems i can only take about 1 led off any of the P terminals ?"Is that correct" . So no problem I will fit a FET buffer that will give up to 2 amps.
Q 1, Is P 3 & 4 terminals momentary in that push a button & 3v is on, release the same button & is off or 0v. ?
Q 2, Will a FET buffer latch on with a 3v momentary switch. IE: Is it latching?
If none of the above, what terminal do I use as a simple on/off switch for the FET.
Thanks
Are any of these LEDs to be automatically switched for direction?
F1 & F2 can sink a couple of Amps, and are automatic, by direction.
F4 can also sink a couple of Amps, and is toggled on & off with the Bind button.
Does that help you?
phil@rctrains.co.uk
Does that help you?
phil@rctrains.co.uk
Are any of these LEDs to be automatically switched for direction? No, but 1 will be using P1 & P2 for that.
F4 can also sink a couple of Amps, and is toggled on & off with the Bind button. Ah! So is the F4 pre programmed to latch. IE: press & release bind once F4 is on, press again & its off.
Does that help you? Thankyou, Yes.
You got it.. :)
F3 can also sink 2Amps, and is momentary, when the Bind button is pressed, it is 'on'..
You got it.. :)
Hi, thanks for the help, but i get lost with electronics terminology. "F3 can also sink 2Amps" i take it means F3 can take a load of 2 Amps" Also i am wondering why Micron says a sink/load of: "(P1..P6), 0V when off, 3.3V when on, max 20mA" Or is this 2amp just momentarily & not constant.
I think you''re confusing your Fs and Ps. The F outputs are FET buffered to 2A. The P outputs are limited to 20mA.
Rik
Rik
Indeed so I always got a bit confused between F’s and P’s when doing Deltang programming. Would have been so much more helpful if the complete thing used a different letter for something that is different. But we are where we are.
I think, in my blog posts, I generally refer to the FET outputs as ABC and the P outputs as 1 - 8 to try and emphasise the difference.
Rik
Errrrr......?
So the motor outputs are H..
The buffered outputs are F..
And the logic outputs are P..
But in future, I will refer to buffered outputs, by the letter-designations 'A' to 'D'. - These are the FET buffered outputs, that can sink 2 Amps.
Errrrr......?
Rik
Oops oh dear sorry did not make myself fully clear! I meant in the instructions that left me going round in circles. In the end I did a logic table to help clear things up in my mind.
