Massoth Switch Decoder
electricity_bill
11 Feb 2010
687
3
Hello
I have a Massoth Switch Decoder with four switched outlets. However, S1 and S4 have stopped working whilst S 2 and S3 are Ok. Checked the CVs and can’t spot any errors. The point motor kicks when connected to S1 whilst checking the CVs. Any ideas?
Bill
Gizzy
36,150
2,278
63
Cambridgeshire
What are the addresses for your decoder outputs?
It seems to work if you have a load on S1....
phils2um
Phil S
11 Sep 2015
1,522
423
Ann Arbor, Michigan
United-States
I assume you checked the wiring to the turnouts and turnout motors themselves.;) You could try a complete reset to ground zero. Check its operation. Then re-program to the switch addresses you want. As I mentioned elsewhere recently, I had to reset a similar decoder multiple times before I finally got it programmed to do what I wanted.
Phil S.
electricity_bill
11 Feb 2010
687
3
They are addressed as 1,2,3,4 and it just kicks when programming CVs
