Massoth PC Interface?
Phil
Trains, Just Trains.
24
28
Oldham, Manchester.
Hello my friend has jusy purchased one of these new unit from massoth
I've tried to install it on his laptop but to no succes, is there something i am missing?
It is the newest one avalable and has had nothing changed or done to it...
i try to open a file but when i try to open the decoder program v1.5 it says i am missing a file but i havent deleted anything.... I'm confused.
Cheers phil
Gizzy
36,169
2,283
63
Cambridgeshire
Re:Massoth PC Interface?
Cheers phil
Make sure the software is compatible with the PC's Operating System.
Then uninstall and reinstall the software from the CD/DVD....
GrahamMills
Many & various. In G scale it is American Diesel.
Lizard, Cornwall, UK
I'm sorry Gizzy but that is a real **** response.
If Massoth have managed to produce a version that is not compatible with his operating system then re-installing will do nothing!!!!
Most Model Railway companies seem to be far behind on PC compatibility, you would almost think that they are still stuck in the Analog world.
Gizzy
36,169
2,283
63
Cambridgeshire
Yep, maybe my quick reply didn't explain that well enough.
I guessing it's a compatibilty issue, as I don't have all the details I need from Phil.
But my (professional) experience of PCs is that compatibility is the most likely problem, followed by a possible corrupted load of the vendor software.
So Phil first make sure your OS is compatible for the Massoth Software.
If it isn't then you need to contact Massoth or return the PC Interface to your vendor if they has sold it to your friend on the basis that it works with his PC's OS.
If the software is compatible, then try an uninstall followed by a reinstall.
mike
Master at annoying..
4,458
Rossendale
and yours was so much better graham... :thumbdown:
muns
Well-Known Member
130
Southampton, U.K.
www.gardenrailoutlet.co.uk
Phil,
Can you explain exactly what is happening, i.e, what you are clicking on and such and what file it is complaiing about.
BTW what OS is the laptop running - the Massoth software is happy on ALL versions of windows from Windows 2000 onwards.
Philbahn
3
74
Swinton Manchester
Mark had a word with Phil. Haddn't losded the software by registering with Massoth.
Think it's ok now
muns
Well-Known Member
130
Southampton, U.K.
Now you have confused me. Why should he need to register with Massoth?
Gizzy
36,169
2,283
63
Cambridgeshire
Is there a activation code that 'registers' the s/w Mark?
Good to hear from Philbahn that the problem appears to be resolved now though....
muns
Well-Known Member
130
Southampton, U.K.
Nope.
Gizzy
36,169
2,283
63
Cambridgeshire
Nope.
Ah well, Phil's got it working now?
Case closed.... :thinking:
Philbahn
3
74
Swinton Manchester
If you go on the site (massoth) and register you can get expanded menus for upgrading. Unlessyou know of another way to access their software? Or am I missing something?
muns
Well-Known Member
130
Southampton, U.K.
You need to register to access the files on Massoth's download center but you dont need to register to use the CV programming software. The Programming unit should come with the software on CD.
I read the Phil's original post to be refering to using the CV programming software and not the Download center.
Philbahn
3
74
Swinton Manchester
Don't think he was refering to the programming unit. He just wanted to up grade his navi etc
muns
Well-Known Member
130
Southampton, U.K.
Hmmm, not sure If I have the right glasses on then 'cos I dont get that from the original post.....
Cheers phil
Philbahn
3
74
Swinton Manchester
I stand corrected Mark. Wasn't aware that they had bought the interface. Was told they just wanted to upgrade the handsets. I've just spoken to Sandy about it
