Hi all,
Currently doing two LS installs on LGB Stainz loco's. I'm having issues with the brake sounds on the LS that is in the first loco. When running and accelerating, I get the brake noise sound at various points. It goes when I hit speed step 6, 11, 16, 21 and 25 but not when I slow down. Has anybody seen this before? I've programmed up the second LS and connected it to just a motor block on it seems to work correctly.
On the loco, I'm connected to the forward/rear/internal lighting socket, Output 1 to smoke, and output 3 to cab light. Also noticed that the chuff noise doesn't drop off when I slow down like it does on the motor block. Pretty sure I've put in the same sound file and cv file in to both. Am I looking at a decoder fault?
