MASSOTH LOOP REVERSER.
steve parberry
G Scale Trains
2
ROSS said:
Anybody got one. . .comments on operation etc.,?
Yes i have one does what it says on the box... i have set it up using the switching tracks as i will eventually have two.. but it is in a triangle and not a reverse loop but the theroy is the same changes the poliarity as the train enters the section and changes it again as it leaves....
robsmorgan
5 Feb 2010
1,655
Ceredigion, Mid Wales, UK
Probably not much help but I was thinking of going down this route, however I was persuaded to 'do the math' and ended up converting to R/C.... no problem with polarity switching plus the Peco Gauge 1 point/switch takes care of itself perfectly well.
Regards
Rob
Gizzy
36,181
2,289
63
Cambridgeshire
MMTS has one.
Works seemlessly with digital locos, but if using analogue engines, then you need to stop in the loop and change the direction of your controller, as I do with the LGB 1015 T sets that I use....
