Ralphmp
The manual that comes with the Massoth Feedback Module mentions 2 modes of operation - "Flank" and "Level" (paras 2.2.1 and 2.2.2 in my manual). Having read this a few times, I'd appreciate it if someone could confirm I've understood the 2 modes correctly.
My interpretation is that
However, if the Feedback Module is in Level mode, then it will react every time a magent-fitted loco passes over it. Using the same scenario as above (contact open at start of operations) then
Could some kind soul confirm my understanding or tell me where I've gone wrong?
Many thanks!
- in Flank mode, the Feedback Module only processes a signal from an attached Track Contact when the contact is moved from an "open" to a "closed" state - e.g. by a passing magnet-fitted loco. If the loco passes over a contact that's already in the closed state, the Track Contact will move to the open state but the Feedback Module will ignore any signal from this state change.
- In Level mode the Feedback Module will act on signals received from the Track Contact moving both from closed to open and open to closed.
- on pass 1, when the passing loco triggers the closing of the contact, a "b" signal is received by the Feedback Module,
- on pass 2, when the passing loco triggers the opening of the contact, an "a" signal is received by the Feedback Module,
- on pass 3, when the passing loco triggers the closing of the contact, a "b" signal is received by the Feedback Module,
- on pass 4, when the passing loco triggers the opening of the contact, an "a" signal is received by the Feedback Module,
- etc., etc.
Many thanks!
