I'm running (or going to be running, when the currently-in-progress line is ready!) an eclectic mix of new and old (some VERY old) LGB locos, plus a few other things - a Piko V260, a Hartland Mack, a couple of Playmobil "bodges" etc. In addition, I've got several older bits of LGB rolling stock such as the post vans, which have track-powered lighting using the old screw-in 19v bulbs.
Now, I've got a Dimax unit with the facility - only available on the newer firmware I understand - to set the maximum track voltage to something lower than the standard 24 volts. What I'm wondering, for the sake of the lighted rolling stock and the older (and the non-LGB) motors, is whether I should set the Dimax down to 19 volts for everything? What brought this to mind right now was the discussions with Gizzy about the MRC decoders, looking up their instructions online I see they state a maximum track voltage input of 21 volts - so the standard Massoth 24 volts might be pushing it a little?
