am gradually digging up more info on these MFX decoders.
There is a bit of inference here, but bear with me.
The CV pattern in the LGB 24741 seems to fit the pattern documented for Marklin's mLD, mSD loco and sound decoders, as documented [in German] at
http://www.maerklin.de/en/products/new-items/decoder/decoder-programmer-for-mld3-and-msd3/
This table of CVs has been posted elsewhere in this forum.
This table does actually fit in with the standard DCC protocol. However, the 'standard' allows for quite a number of manufacturer specific CV definitions, and Marklin has taken full advantage of this. So the term standard, when applied to DCC CVs, seems to be rather a movable feast. Each manufacturer [not just Marklin] has quite a number of manufacturer specific CVs in their list. These are not deviations from the NRMA standard, they are simply not nailed down by the standard! [This may be common knowledge to many readers, but maybe not to all of you.]
Unfortunately, although the manufacturer code for this decoder is TRIX, the CV pattern does not seem to be the one used by TRIX for their branded decoders.
Decoderpro does not appear to have a specific CV program for any Marklin decoder, let alone this mLD/mSD pattern.
The actual decoders in the Marklin/LGB MFX locos may, or may not be this mLD/mSD, but the pattern in the LGB 24741 matches this pattern, as far as it is documented.
Further digging reveals that the mLD/mSD decoders can be programmed using a Marlin USB dongle on a PC with some free Marklin software. I found this piece of text in a very long Marklin manual: [translated from German by Bing]
Programming:
-MDP 60971 decoder programmer, stick with USB and decoder interface.
Programming tool mDT3, software for fast programming of new
LokDecoder3 and SoundDecoder3 on the PC
Retrofit decoder with 21-pin interface:
-60972 decoder mLD3 (without sound module)
-60975 sound decoder mSD3 with preset Steam loco sound
-60976 sound decoder mSD3 with pre-set sound of diesel locomotive
-60977 sound decoder mSD3 with preset E-Lok-sound
I also found this link, thankfully in English, that describes that very device:
It costs about 80 Euros from Marklin direct - probably cheaper elsewhere.
Now the questions are:
1) Is the decoder in the LGB locos able to be programmed with this device too?
2) Is it really necessary, as, armed with the list of Marklin DCC CVs from the earlier link, the decoder can be programmed using standard DCC tools [once it has been initialised]. I programmed mine with the single CV programmer on the Massoth Dimax via the Massoth 1200Z central station on my programming track.
3) Again, armed with the Marklin List, could the decoder be read, via Decoderpro, into one of the
generic NRMA templates at the top of its list of templates, and then programmed using the menus. [I am going to try this later]
I would like to see Marklin actually publish the full name and version of the decoders it is using in its new MFX LGB locos, and indeed say if they are the same as these mLD/mSD items. I suspect they are probably not, as these are probably for HO models - but who knows?
At least it might make it easier to find published info about the LGB decoders, if we knew their names! Anyone know someone at Marklin?
