justme igor
![Netherlands Country flag](https://gscalecentral.net/misc/flags/shiny/32/Netherlands.png)
If i would like to have a couple of turnouts that are easy to reach, then I wouldn't have thought about this.
There are some simple and very good solutions for a turnout to direct your train to a other track, the most genius and simplest of them all: a simple spring on two sleepers.
I think one of the forum members here, come up with that idea.
For turnouts in nasty corners or out of reach, i thought of motorising them with those simple Arduino motors with a reverse polarity switch and add some "one click switch"(?pulse switch?)incl with some battery's( i dont like wires that are way to long).
I even made a setup experiment with some 18650 li ions, a 2 s bms and a small solar panel, it did the job very good, except the motor is a bit to strong.
The arbore resistance of the dc motor is strong enough to hold the points into place without any power.
But when it must be set on a other track, the kick of the dc motor is just to strong, it will do a ~10 to 25 times its job before you will need to repair the mechanics or a sleeper, motor will be fine.
I even experimented with a home made solenoid, wind copper wire around a nail---> surprise the battery's are dead in no time because it needs power all the time.
Or drool to expensive solutions, no problem if you have a couple of scissors crossovers.
But not for what I want to achieve..
I had an idea at work this afternoon.
With just 2 syringes and a water filled tube.
No compressed air, you will need to much equipment and or other stuff, water and oil are liquids that you can not compress.
I think this is workable?
The experiment did work, again and again and again, spend 5 minutes with it, back and forward, back and forward, ect.
I only need to secure the turnout mechanism and the "cylinder switch"
![20220105_154752.jpg 20220105_154752.jpg](https://cdn.gscalecentral.net/2022/01/thumb/438835_20220105_154752.jpg)
Take out the plunger and take of the rubber.
Fill the hose with water or oil.
![20220105_154824.jpg 20220105_154824.jpg](https://cdn.gscalecentral.net/2022/01/thumb/438838_20220105_154824.jpg)
Make your throw bar from 6mm dia alu pipe.
I did not glue it together for this quick experiment, but i will for the real experiment.
![20220105_153811.jpg 20220105_153811.jpg](https://cdn.gscalecentral.net/2022/01/thumb/438843_20220105_153811.jpg)
The points are still "relaxed" becous i needed to fix the syringe and adjust the bar to its starting point.
![20220105_153853.jpg 20220105_153853.jpg](https://cdn.gscalecentral.net/2022/01/thumb/438839_20220105_153853.jpg)
![20220105_154345.jpg 20220105_154345.jpg](https://cdn.gscalecentral.net/2022/01/thumb/438833_20220105_154345.jpg)
Syringe pressed in to build up pressure to press the points against one rail.
![20220105_154229.jpg 20220105_154229.jpg](https://cdn.gscalecentral.net/2022/01/thumb/438842_20220105_154229.jpg)
Syringe poled back to create a vacuum.
Now those points look out of shape and bend but the box of nails is holding the syringe down to the bench so it lifts up the throw-bar.
And it is abs 3d printed, looks nice but you dont want to have this in your track as i stated in my track making topic, a scissors crossover is really at the limit due to temp differences.
What i can think of the down sides:
It can freeze up, or going to be to hot in the full sun - thin motor oil or silicone oil will be the solution.
Without properly connecting the hoses you get a leak, glue or something like a hose clamp.
Some oils will eat the rubber, some not
What i can think of the positive side:
Very cheap and very easy, 10 euro for 25 meters of hose and not even 1 euro incl shipment for 10! syringes, or ask your vet
What are your ideas to let a turnout work?
And your ideas/thoughts/comments about my idea?
With best regards Igor
Ps it toke me longer to make this post than to make the experiment
