I don't have much knowledge of signalling, but a friend mentioned it would be nice to operate semaphore signals with a servo motor and ADD THE BOUNCE FUNCTION.
Now from my limited observation, UPPER quadrant signals had a motor on the signal head and operated pretty smoothly.
But LOWER quadrants were usually operated by a wire to pull them clear and then 'fell' back to Stop when the wire tension released. I've never seen one operate, but a trawl of Youtube, found a couple of example of one going from clear to Stop with lots of bouncing.
https://www.youtube.com/watch?feature=player_detailpage&v=V31E8pmml3Q#t=40
Does anyone know if they also 'bounced' when going from Stop to clear??? Any videos showing this??
From the youtube video I examined every frame and determined the following timing for the bouncing from clear to Stop:
Initially 'clear' at 50deg down.
Takes 0.56 sec to rise to horizontal
Then bounces down 18 degrees in 0.40 sec (0.98sec)
Stays there for 0.08sec, then (1.06s)
Rises to horizontall in 0.48sec (1.52s)
Bounces back down 6 degrees in 0.18s (1.76)
Waits 0.08s, (1.84s)
then bounces back up to horizontal in 0.32sec (2.16s) and stops.
Any comments???
Any comments???
