Dodod driver
I am new to Forum messaging, so please excuse any errors.
I have recently bought a Massoth Navigator and a LGB MTS III Central Station, connected by a wireless link. I have used an older MTS system for some years in a very simple manner, so have limited knowledge of this.
When using the new items, after a while the right-hand LED on the MTS III comes on as a solid yellow light, and all loco and point control is lost from the Navigator. The loco continues to run. I have to turn off the 240V and wait maybe 20 minutes. The system will then return to normal when I put the 240V back on. My old MTS system was Parallel, and never suffered from this.
I have tried disconnecting the point decoders, swapped the Central Station for a replacement, and replaced the wireless link with hardwiring, but the problem continues. However, turning off the battery charging facility and using non-rechargeable batteries in the Navigator has reduced the frequency of the loss of control.
The Navigator shows 1.89d, which I believe is the software update number.
Has anyone else come across this problem and can suggest a solution?
Thank you.
Thank you.
