Multi-Train System This model has a „D“ gearbox and decoder interface.It can be equipped with a LGB Multi-Train System Decoder (55020) using a Decoder Interface Cable (55026). When the decoder is installed, the Train Mouse loco function button will control multiple functions, depending on the number of times the button is pushed.
Push the button in intervals of 0.6 to 1.0 second. Press 1x: Whistle Press 2x: Bell Press 3x: Smoke generator on/off Press 4x: Sound on/off Press 5x: Air pump, slow Press 6x: Brake Press 7x: Coal shoveling Press 8x: Air pump, fast For more information, contact your authorized LGB retailer or an LGB service station (see Factory Service). We recommend factory installation of decoders (see Factory Service). Hint: If you install the decoder yourself, reset the DIP-switches on the smaller of the two circuit boards (motor-light circuit) inside the model. For Multi-Train System operation, all four DIP-switches should be set to OFF.
