Hi all,
Has anybody got a european source for a replacement circuit board for the LGB track cleaner - E129813 ? I've found some in the USA, but if I can find a more local source that would be great!
Grootspoor were showing as having some in stock when last checked (see thread link), however the UK postage is a bit of a killer unless you are ordering other items.
What appears to be the issue? Is the whole board dead or do you suspect defective components? I only ask as i've recently managed to successfully revive one that I suspected to be otherwise dead and it now works like a charm.
Also, on an unrelated note, i'm not sure if there is an issue with the messaging system, but I have sent you a number of separate private messages in relation to the drive unit for the 2066 Wismar Railbus following your reply on the thread I raised, but haven't received any response as yet. Have you had anything come through at your end?
