Greg Elmassian
Guest
		A few comments, paralleling what has already been said:
live frogs are great for short wheelbase locos, or ones with few pickups, but powering the frog has it's own issues.
The LGB frogs with the metal inserts in the bottom of the flangeway is a workaround that has been utilized on many scales, we even have it in Marklin Z scale. Unfortunately, it depends on a "flange bearing" frog, where the wheel tread no longer rides on the rails at the frog, but the wheel flange is the contact point. This lifting of the wheel off the rails and then riding on the flange and then going clonk back to the rail head is not "smooth", and has various negative factors, if you have a loco without a sprung suspension, lifting a wheel may lift the other wheels on that side and break contact, also it depends on the flange on the wheel, all your locos will want the same flange depth, and this is rare between brands.
