Sarah Winfield
I seem to recall a similar question but I can't seem to find the answer.
My point will change direction fine one way but the other it needs some help. I have had the cover off and assume it is the spring which is the problem.
Either it is installed incorrectly or, though use, the spring has become slack(!).
Would it be possible please for a member with a similar point to photograph the inside of the switching mechanism so I can compare it with my point?
Thank you in anticipation,
Sarah Winfield
Sarah Winfield
