LGB Caboose 42710
Graham
In Smoggy Land
10 Mar 2016
380
277
Middlesbrough, England
I have just acquired the LGB Caboose 42710 :inlove: and can any one tell me if in the prototype the red light on the roof was a fixed light or flashing as I would like to kit this one out with a full set of lights,
kim
retired at last
27 Apr 2015
792
563
72
Cleveleys
I do stand open to correction on this Graham but the lights on a caboose were a fixed light and the red flashing light came in as an end of train warning when the caboose was discontinued.
stevedenver
255
Well on this wpy style caboose,
The round molded in lamps with dummy white reflectors were in fact the white spotlights. The light on the cupola was a rotating beacon.
On later versions of this caboose, lgb added US style separate lanterns. They offer their own charm and ease of inserting the lgb brass socket and 18v yellow bulb.
While speculation, i would think the roof lantern, being amber and very bright would penetrate snowing or blizzard conditions better than red. Probably a good thing if stopped for a blocked tack.
I lighted the spotlight lamps on mine. I used two lgb 5v reds wired in series. They are vivid and look great. I simply set them into the round housing, without an lgb style 5v plug.
My roof lantern is a flashing amber led, runs off AA , i think 2.
If i were to do this now, id make every lamp an led. A pulsing led, (grows bright and then dims) similar to a light house style might be perfect depending on the pulse rate.
but, drgw only ran cabbose lanterns, and nothing that resembles the lgb wpy model. So, you can apply rule 8. In so doing, let me say bight blue LEDs , perhaps for the cupola light, would look very good,imho. (Did this on one of my 2033s that blew aflasher circuit, they look great).
Have fun. Lights are good!
Graham
In Smoggy Land
10 Mar 2016
380
277
Thanks for the I info - rule 8 and my box of led`s will decide. I'm assuming the long end goes to the front and the short end to the rear?
stockers
3,795
65
Nr. Ashford, Kent. England.
The long leg is the positive terminal.
Graham
In Smoggy Land
10 Mar 2016
380
277
On a similar vein if I install LED`s do I need to use bridge rectifiers so that they work which ever way the caboose is on the track
stockers
3,795
65
Yes. for DC. Look on ebay - they are a few pence.
3,522
If you are analogue, and want the lights on in both directions of travel. - Not sure if you are talking internal lights.
If you are DCC, then you do not need a bridge rectifier..
