Hi
I am very close to running the Lighthouse, Gorsebank and Bride Railway under computer control but have hit a very strange problem with 2 different 55070 feedback modules.
When either 55070 is connected to the Massoth Dimax 600A transducer module without any wiring connected to the 55070 everything else works fine, points operate via decoders etc.
With Two track contacts connected to terminals 129a and 129b of either 55070 module the contacts are read by my PCs running stelwerk easy. As soon as I connect the common connection of a second pair of contacts to the common terminal between terminals 130a and 130b or any other common on the module all point control is lost and no contacts are read.
If I remove the original track contacts from terminals 129a and b and put them, or any other contacts, into any other pair of terminals they work but as soon as I touch a common wire from any other pair of contacts onto any other common terminal the problem returns.
I have tried connecting a coil of single core cable to a common, this does not cause an issue.
The wiring between track contacts and 55070 modules is brand new, run under the soil in the garden and no voltage, as you expect, is measured across the track contact wires
This has got me baffled, any help would be much appreciated.
Ian
Ian
