idlemarvel
Neither idle nor a marvel
I recently bought some of these second hand. I am always impressed with LGB build quality and production and these signals are no exception, but the design of the colour switching mechanism leaves something to be desired.
For those who have not seen one of these (pictures below), they use the same point motor base as the semaphore signals, and the same two wire connection to transfer power to the lights, but the weak point is that it uses a magnet fitted to the point motor to trip a reed switch inside the signal mast to switch between red and green. I cannot believe such a mechanism would survive more than a few weeks outdoors. It sort of works, and I can see why LGB have done it, to maintain compatibility with their other semaphore signals, and so they can use the same controls based on isolating tracks etc, but it really is a bit of a poor design IMO.
Base point motor with grey signal mast incorporating reed switch with black magnet block to the right, which slides to and fro driven by the point motor.
Inside base of signal mast showing two power pins and reed switch.
If anyone from LGB reads this forum perhaps they could reconsider the design and for heaven's sake please start using LEDs instead of filament bulbs!
