LGB 5080 Control Box Question
Madman
I'm not sure that I understand how the 5080 control box is supposed to operate, or should I say be wired.
In the LGB instruction pamphlet, the diagram shows running power to the terminals marked 1-2 or 3-4. AC or DC can be used as per the instructions. All well and good so far. Now if I want to operate something that uses DC power, the instructions show simply running a pair of conductors from any set of the four sets of terminals on the box. By pressing the rocker switch on, the item should be powered, which it is. However, when I pressed any of the three remaining switches, power was also sent to the item.
So I only have one pair of conductors wired to the box, yet all four switches activate those two conductors.
Any ideas?
As you suspect each switch should independently feed one wire of its circuit with the other wire common.
It sounds as if yours is incorrectly connected, maybe internally. With the old four digit number it must be an old unit, probably pre-owned, and a previous owner may have messed with it.
If it's any help here's a link to a later version of the instructions. Please note it also includes details of the other, EPL turnout motor, switch box.
http://www.champex-linden.de/lgb_pr...85256A17006A1A94/$FILE/51750_51800_072002.pdf < Link To http://www.champex-linden...51750_51800_072002.pdf
Thanks Neil. It turned out to be a malfunctioning 5080 box.
