This is my first experience repairing one of the LGB/Marklin 28 Pin sound decoders, this one installed in an LGB 26844 Mallet Sound Steamer. The problem: All loco functions would operate except the chuff sounds and installed Massoth pulsed smoker. I installed the LGB/Marklin replacement sound decoder that initially corrected both the chuff sound and smoker operating issue; but while installing new piston plastic tubing and then testing, the smoker failed, and of course, the chuff pulse to the decoder stopped. I replaced the smoker with a new Massoth pulsed smoke unit and the chuff sounds were restored, the smoker pulses from the Hall Sensor inputs, but doesn't generate smoke. I measured the track power output from the decoder's AUX 8 terminal for the smoker and it's now only generating 6.4 volts instead of the required 18 volts to heat the smoker's heating element.
My help questions: 1. Does anyone know what CV or CVs I need to use to try to adjust the AUX 8 Output's voltage back up to full track power? 2. I've been using my Massoth Navigator to read and write the CVs on this decoder with no problem. But I'm wondering if I could use my Massoth PC Interface Module/Massoth Service Tool, or my ESU Programming Module to program these Marklin mfx/dcc/dc sound decoders? Or do I need to wait for the LGB/Marklin CS3+ Central Station I've ordered in order to properly diagnose, program CVs, and install Marklin sound files on these LGB/Marklin mfx/dcc/dc decoders?
