This is often the case with these it seems? Not sure if it is down to gearing, the motor or the wheel diameter.Got it working!! The loco runs a bit faster then the tender I've noticed though.
Yes... as I guess you've already found out from your next post?I don't unfortunately.. Would simply soldering the inner contact pins to the outer pins get it running?
Good idea! I'm uploading a video of it, at some point I don't know when I might buy a more suitable motor if it doesn't work out as I'm worried of burning one of the two motors out.I'd run the tender in for a while, a good half an hour in each direction - either on test rollers if you have them, otherwise on a simple loop of track (or just put it up on blocks, clip power to the skates and let it run on the spot). That may bed everything in and bring the speed up a little.
That's what I thought! I've looked all over at it but I can't see anything wrong! It's basically brand new I've hardly ran it because it couldn't pull anythingLooks much happier than before! Still makes me think there must have been something not running freely in the tender, and that could still be the case now?
I doubt LGB would knowingly sell a loco that by design (with only one motor) could hardly pull itself round corners, I'd have been checking the skates and wheel bearings.
I'm going to run it in tomorrow as I've got to head of to work, I didn't apply any grease as there was already quite a lot on the gears. I get the feeling a new motor is going to be required as the Schoma was always a bit slow. But I'll give it a shot!
If the gears were already greased, then no more should be needed - I assumed they might be "dry" as a motor was not factory-fitted.
Re the motor itself, I had obviously not read your earlier posts carefully enough, I had missed the fact that you were trying the old motor out of your Schoema! D'oh, sorry......
I'd put that back in the Schoema and fit a brand new one in the tender, which should be better matched to the effectively new motor in the loco.
