I'm about to post some test results and conclusions.
Its not that difficult to carry out a technical test, but translating the results into helpful language for the layman is a bit more of a challenge. Also on a forum posts have to be relatively brief and its difficult to know what to omit.
Please let me know if there are things that could be explained better.
I will carry out some more tests on a range of typical LEDs used in G Scale but I would be surprised if the general conclusions change. The physics of the electrical circuit are the same. The photometric qualities are another matter.
I'm planning more testing: apart from extending the range of LEDs tested, I think there may be some thermal effects that I have not evaluated. And the behavior of LEDs on DCC also requires separate study. What does DCC voltage mean (peak to peak, root mean square, average) and how is it affected by commands? And how does lighting affect RailCom, or does it not matter in G Scale?
What is beyond me is producing a guide on how to illuminate your railway. For a start, such lighting is largely decorative and more an art form than an engineering exercise. Also the photometric data that is used for calculating commercial and industrial lighting designs is not available. Its 'rule of thumb' and your thumbs may be different to mine!
One aspect of photometric characteristics may be helpful: the ultra bright LEDs tend to achieve their brightness by a very narrow angle of view (20-30 degrees), rather like a spotlight. That may be a good choice for loco headlights, for example. The wider viewing angle LEDs are better for general illumination such as platform lighting and interior lighting. But it all depends on YOUR thumb. Remember Rule 8.
Please also note that the human eye does not respond to light in a linear way. 200 lux will appear about twice as bright as 100 lux, but you need to increase to 400 lux to achieve another apparent doubling in light. And then 800, 1600 etc. That's a fairly huge simplification. But you can easily limit a high output LED by varying the resistor. I'm not going to go into photometric calculations: they make Ohm's Law seem simple
