Jack plug adaptors
KeithT
190
Nr Manchester
I think this is the correct place for this query.
I want to light some buildings from a 3v, 4 way transformer instead of by the existing battery method.
The connectors are 3.5mm jack plugs which I need to convert to sockets to fit the buildings.
This means I need double ended female adaptors.
I can't find any in the various spares suppliers catalogues.
Do such things exist?
Gizzy
36,167
2,283
63
Cambridgeshire
I believe they do exist, but you may have to try RS or Farnells Keith.
If I get time and remember, I'll have a look on the RS website later tonight.... http://rswww.com/
ntpntpntp
275
UK
United-Kingdom
this type of thing?
http://www.maplin.co.uk/Search?criteria=3.5mm+jack+coupler
KeithT
190
Nr Manchester
KeithT
190
Nr Manchester
I had another look at the RS site.
They show these
which look and sound to be what I need but clicking on the link doesn't show them anywhere I could see.
Gizzy
36,167
2,283
63
Cambridgeshire
They show these
images
I've not seen that type of female through connector before, only the audio type 3.5 mm jack plugs.
The ones in your photo are low voltage power connectors, and I doubt if what you want exists, but you should be able to get the female sockets that mount on a pcb instead?
If you used veroboard pcb, you could solder your lamps/leds to it....
KeithT
190
Nr Manchester
They show these
images
Thanks Gizzy, I suspected I was looking for something that didn't exist.
The buildings involved are mainly Lemax and Premier ones, they each come with a mains adaptor (or battery box) but it means having 9 of the things plugged into a multi point socket and I am trying to reduce the number to three.
It would probably be the simplest solution for me to cut off the jack plugs and solder new connectors in their places.
I have several redundant ones from interchangeable mains adaptors which would do the job.
KeithT
190
Nr Manchester
ROSS said:
Try Dolls House stores. They carry low voltage lighting wiring..plugs etc by CIRKIT (usually) Hobbies catalogue (WHS) is a good place to look..
Thanks Ross
What with these suggestions and the connectors offered on your site I have gone from being stuck for a solution to being spoiled for choice!
I will need to do some headscratching to get the best option.
