I had similar concerns. You have to use a laser or photocopier. I have a Brother Laser so its going to be more complex for me but I found a good laser printer for AU$25.... anyway these are the instructions;
Product Information
Sale is for 10sheets. Press-n-Peel Blue Transfer Film - print PCB image on a laser printer and transfer it to PCB. Sold by letter size (8.5 x 11”) sheets.
Product Information
dipmicro Code DE2706
Click for more lot sizes
Lot Size 10 sheets
Manufacturer Techniks
Manufacturer P/N PNPB
Stock Type New from manufacturer
Restockable? Yes, we can get more. ASK
Shipping Weight 0.18kg / 6.35oz
Technical Summary
Packaging bulk
This paper cannot be used with INKJET printers!
If you intend to use BROTHER printers, keep in mind that Brother toners have higher melting temperature than other toners. It may be difficult to transfer image made by BROTHER printer. I was able to make a transfer using BROTHER printer, but only by hand and iron pressing for 1-2 minutes. GBC laminator did not transfer even smallest piece of image made by BROTHER printer. If you have BROTHER, first experiment several times or get different laser printer, there are very inexpensive models out there.
PnP Blue produces high quality prototype PCB resist layouts making your design ready to etch. PnP Blue is a Mylar (Polyester) backed material in which several layers of release agents and resist coatings are applied. An image is printed or photocopied onto this film, using a laser printer or photocopier (dry toner based), and subsequently ironed or pressed onto a cleaned copper clad board. The image area applied to the film is subsequently transferred to the copper board, along with the high quality resist (blue). The film is removed and resulting board is ready to etch in ferric chloride.
How to
Photocopy or Laser Print circuit image onto the dull side (emulsion) of Press-n-Peel Image Transfer Film.
Prepare: Clothes Iron, Steel Wool #00 (or SOS/Brillo with all the soap washed out), Packaging Tape,Photocopy or Laser Printed Circuit Image, & Directions
Prepare Press-N-peel Press-N-peel
Cut Press-n-Peel, leaving a 1/4" border around the circuit image. Cut board to size. Clean copper board with steel wool, S.O.S. or Brillo pads. Rinse cleaned board with soap and water. Be sure to remove all soap residue. Dry thoroughly with lint-free cloth. Be sure to scrape any burrs that appear on the edge of the board that may have resulted from the cutting/shearing process. Burrs tend to keep the iron from making solid contact with the Press-n-Peel Film
Clean copper board Cut Press-N-peel
Place Press-n-Peel with image face down onto clean copper board. Iron the Press-n-Peel Film to the board a peice of plain paper between the iron and the film to reduce friction. Temperature setting on the iron is critical, and dependant upon your laser printer or photocopier. Suggested starting temperature is 275-325 degrees F. Iron setting is generally "polyester". Iron temperatures vary. Iron until board has completely and fully reached the temperature of the iron. Time varies with the size and thickness of the board. Generally this is 1.5 to 10 min. DO NOT USE THE STEAM SETTING!
