IP Engineering open cattle wagon
Just remembered that the source for the resin figures was Motley Miniatures - specials - Motley Miniatures
I've been wondering if I could make a plaster cast of a load of sheep heads and backs using plasticine as a mould. Has anyone any experience or tips for using plaster and plasticine?
Rik
Rik
I know that you have had experience with Casting Resin, have you tried this as a master. Extremely easy to use with just hand mixing to create a Master Mould. A friend gave me some as an Xmas pressy and I have been well pleased with it.
Thanks. That does look like a neat approach. I picked up some PlayDoh in my local cheapo shop and will give it a try as I only need to mould each one once. However, if I get around to making a rake of W&LLR sheep wagons, I might give this a try....
Rik
Had a first attempt at creating a plaster cast sheep load. I suppose it might look OK from several metres with eyes half closed. I might try another one with the sheep bunched more closely together - ie mostly backs and heads with minimal gaps between the sheep. This is actually quite tricky as when a new sheep is pressed into the moulding medium (ie PlayDoh), it squashes the impressions which have been made previously and they become mishapen and I end up with humpty backed sheep. However, for a first effort .......
The casting - don't look too closely at their faces - a bit scary!
The load inserted. I suppose it looks a bit better inside the wagon
Rik
Rik
Sorry to be so well negative Rik, you always get it right but perhaps not this time. Think some time in £1 shops looking for cheep sheep may be a better use of time? Oh ‘cheep sheep’ almost poetic.
Sheep don't go cheap though. They go baaaaa
The wagons look really good Rik, is the Tralee wagon very tall or just large compared to the generic sheep wagon?
Regarding the sheep, what about dividers? That way you could continue using your current amount of sheep but just over a smaller area of the wagon. If you were to recast the sheep block, have less space between each animal and less black on show?
The footprint of the Tralee wagon is a bit larger but not by much - but as you say it is taller. When I bought it, the chap on the stall at Llanfair said it was 10mm scale - but I don't think so. A 10mm scale wagon would be massive. I've not got any drawings of T&D cattle wagons so can't check the dimensions
Dividers sound like a good idea if all else fails. Yes, I thought I'd have another go but bunching them as tightly together as I can, as you say so the amount of visible floor space is minimal. As I mentioned, this is quite tricky as the PlayDoh distorts when a new sheep is squidged into it.
Rik
Hi Jon
I agree, it's not one of my most successful experiments - but I'm always willing to give these things a try. I do keep an eye open for cheap sheep in bargain shops. I've noticed in the farm packs that generally there is one sheep plus at load of other stuff like chickens, pigs, cows and horses all in the wrong scale, so I'd end up with livestock I couldn't really use. A pity they don't market flocks of sheep and herds of cows in the cheap packs.
I have got a mate experimenting with 3D printing the backs of the six sheep bunched together. They cover about 1/3 of the area of the wagon. I've sent him a series of photos of the bunched sheep taken from various heights and angles and he's used a fancy bit of software to stitch them together into a 3D image. He reckons it will take about 8 hours to print one bunch - so 24 hours for one wagon load!
Rik
PS - I spent yesterday attempting to create a horse harness for the coal cart I made a while ago. So, I've had to research horse harnesses. This hobby is certainly varied and interesting........
Why not just cast each "sheep-back" individually (though maybe six or eight at a time)? No risk of distortion to the mould from a second impression (because there wouldn't be one), and then arrange as many "sheep-backs" as you can on a raised flat platform to fit inside the wagon.
Best wishes
Best wishes
Good idea. Gregh has also suggested this. I might give it a try.
Rik
A screenshot of the 3D image. He still needs to tidy up the base but he's getting closer.
Rik
Hi Jon
Rik
Look for my PM Rik.
Sheep in the shops seem either too big, too small, too few or too dreadful!
I'm working on a sheep project here in Canada. The plan is to make my sheep patterns of polymer clay, then make molds in silicone, finally casting the sheep in polyester resin.
I plan to make both individual and bunched sheep. I'm just starting - I've made one sheep so far and still have a long way to go on this because I'm concentrating on my human figures at the moment.
In N America sheep were shipped in double decked stock cars:
Were I modeling sheep for open cars like yours, I'd bunch them in tightly so they wouldn't fall all over the car. I suspect the real railways would have done this, but I'm no expert.
Ordinary stock cars had only a lower floor and were used to transport large stock. Many were divided into wooden pens for individual animals, primarily cattle, but also bulls and horses. Otherwise there would be a great deal of knocking about. If necessary these beasts might be tied to the timbers as well. An aisle down the middle was usual, to feed and water the stock on the long trips common here.
I saw a video of sheep being transported in an open car in Britain. The sheep were penned into the ends and their freedom of movement quite restricted. A shepherd sat between the folded-up ramps which acted as doors. In this case the sheep were packed in for what I believe was a short run.
You're lucky! If you pack them into typical British solid-sided short wagons you won't have to model the trickiest bit - the legs - at all!
Very interesting topic and if you want sounds,I use a Sound Blaster unit for cow sounds in my stock trains,I`m sure they make a sheep sound card and the unit fits inside the car through the door although in your case with the open cars hiding may be a problem,when using the small steam loco sound card I built a crate to house it and load it on a flat car.My unit came from Glendale but alas the shop now a fond memory but can recommend the unit,just a suggestion;);)
Ahh, Johnny, I see you are planning on extending your range of figures. Good choice, sheep.
At one time I tried "Rounding-up" a flock of sheep to populate some of my Bachmann, and LGB, North American type stock cars.
The quantity needed for each car; double if we made the cars double deckers would have driven me into bankruptcy, unless I simply went for the Playmobile sheep...if I could have found some.
Their sheep sure as heck aren't perfect, but at least they seemed to be reasonably priced. At the time, I was led to believe I could obtain them in bag lots, but no dealers/distributors in Canada could provide them.
The only ones I could have obtained were packaged, 3 sheep and a shepherd, in each bag. If I had gone that road, I would have ended up with a grossly over-populated town of shepherds, with few sheep.
After considering having two pens at some stations, a small one for sheep, and a larger one equipped with an outhouse, a bar, and entertainment for the shepherds; I discarded the whole project.
We run our stock cars with imaginary sheep...!!
BTW; at one time LGB produced their stock cars in a green colour, lettered for the D&RGW, and the car number was followed by a "D", indicating a double deked car....but there was no second deck in the LGB car. Normally the D&RGW NG cars were painted Black, and Rio Grand Southern cars were a red colour. Often SG railroads used a lime based white paint to sterilize the bottom few feet of the sides and the floor of their stock cars. In service, straw was usually spread on the floors/decks, before loading.
Hi John (Johnny?).
That sounds like an interesting development. My problem is really one of finance. The six sheep I have bought so far were £5 each. They take up 1/3 of the wagon space when bunched together. So, to fill the wagon would cost me £90, which seems somewhat excessive when the wagon itself cost half of that. I'm sure your resin castings will be great but to make them cost effective you will presumably have to charge somewhere in that region. I'm gonna have to find a cheaper homespun way of filling my wagons.
Rik
