Installing Massoth XL DCC Power Decoder into LGB F7A Sound Diesel
LGB333
Active Member
TRADER
15 Feb 2015
685
43
McLean Virginia
www.olddominionrailways.com
Hello DCC Colleages - I sold a customer a Massoth XL DCC Driving/Power Decoder who tried to install it into his LGB F7A Diesel on the factory-installed interfaces. The LGB Owner's Instructions call for installing two LGB 55021 DCC Decoder, of course not produced anymore, so the substitute is Massoth L DCC Decoder, one for each motor. He's asked me for advice on why the locomotive runs in a jerky mode. Not being an expert in the old LGB MTS/DCC Interface technology, my only thought is the factory-main board can't handle sharing the DCC input from one 4 amp decoder instead of two separately attached 2 amp decoders.
Can anyone confirm my theory and advice to instead use two Massoth L Decoders instead of the one XL Decoder. Or someone advise how he can wire the installation so the factory-main board interface will work properly using only one Massoth XL DCC decoder?
Thanks!
3,505
Did it run OK on analogue? - DCC does not 'cure-all'..
Has he sent you a photo of his installation? - There may be a simple error?
Both sets of pickup / motor pins connected?
muns
Well-Known Member
130
Southampton, U.K.
www.gardenrailoutlet.co.uk
I think you will find you need to connect the XL to BOTH of the 55021 interfaces.
