Riograndad
The weathering on the Indy has finally started,the dust and first rust wash coats now on and some oil stain around the tender axle boxes but I need some more paint colours and some new very fine brushes to finish it off,some rust damage on the cab sheets needs to be a little deeper maybe even drilling some rust "holes"although not sure at the moment as it would depend on the thickness of the plastic.I have only done this on custom cabs in the past when using plasticard so rust holes worked well as appeared to be thin metal so more consideration needed on that one,the rear of the cab also needs some more work together with the handrails.I noticed that the bell and whistle activating arms were both on the firemans side so when the whistle was put onto the engineers side of the cab the arm was facing forwards so a new whistle was knocked up with some scrap brass rod and some plastic tube(bell rope still to go on)The next step is a visit to the model shop for some more paint and then on with phase 2
