Thanks for the pics, I think the LGB wagons will work for loading peat that is milled already. Need to figure out where to lay in the loading spur on my railway so I can get the needed track. That way when warmer spring weather arrives in a couple months I can start the changes to the railway. Probably going to stick with LGB track due to availablity localy for me. Local shop deals in estates of trains with a focus on G scale. They are the reborn Watts Train Shop, which was a power house for LGB trains back in the day. Anything 32mm track wise I have to special order and its quite expensive, more than brand new LGB track. Mike
Hi Dodgy ,
I use PECO 32mm , which is not terribly expensive . It is also very good stuff ; if you can get some second hand O gauge by PECO , any little kinks and bends in the track make for a good copy of the prototype , sleeper spacing can be either cut to suit or covered over with a thin layer of peat . If you use the term "ties" for "sleepers" the same thing applies . Tee hee , the common language we share does have its little foibles , don't ?
You are quite right in saying LGB field stuff will suit , and there are some good kits available ----try the Regner Agents wherever is convenient .
I would advise against tractor loading of peat wagons out in the bog , even the multiple wheeled tractors have a nasty habit of sinking . You can get away with it if the bog is drained , this is done by bulldozers cutting drains and the field is left to drain for some time before cutting peat . If you want block peat you cut it wetter than the shredded peat , the soggy blocks are left to dry and take on a quite solid state which is easier to handle for domestic fires .
