Pauly said:
I need a way of producing my own track suitable for electric engines.
it doesnt need to be out-doors resistant or good looking it just needs to work.
Hi Pauly,
I must admit I have been disappointed at the way track has increased in price ever since I contemplated extending my 'test track' into a proper layout. There are a number of issues that you might consider which may affect any recommendation that those with more experience may make.
First, you state 'suitable for electric engines' and from this I assume you mean track powered (nominal) 24V locomotives. If so, I would be wary of aluminum since the non conducting oxide coating that it forms on the surface would need to be cleaned off regularly. In my experience, unacceptably often and far too much effort, but I have not used aluminum for G scale track because of previous problems in other applications. Perhaps others with relevant experience can advise? Indeed if the aluminum is anodized (as is normal from my usual sources) it is about as conductive as a plate! My plates are made of porcelain, one of the traditional insulating materials (sorry guys -Frank/tac/stockers/et al. - I could not resist that!)
My indoor test track is plated steel and corroded badly when left boxed in the garage over the winter. It causes very uneven running over the corroded sections where the plating has oxidized despite relatively vigorous rubbing with a nylon pan scourer. It's so bad that I intend to remove my outdoor brass test track and use it for the indoors test track.
You do not mention switches (turnouts / points) which implies that you are looking at storage tracks only. If not, I suggest that the astronomical cost of these items (in my budget) may well influence what kind of straight track you use. On the other hand, you may be using a traverser, or some similar storage arrangement. Do you need to power the locos along all the track, or can sections be made unpowered for storage of rolling stock?
They say that beauty is in the eye of the beholder and what is not good looking to you at 10PM may well be viewed differently at 2AM after a few drinks. That comment was meant as a bit of fun, but do you want your track to resemble track at all, or is it just a means of supporting your trains and it does not matter what others seeing it may think, and does it depend on who is looking at it?
Although you may feel that a 'bit of cleaning' before you use the track is acceptable to reduce the initial cost, believe me when you skimp on the cleaning (which you will) the track won't 'just work'!
Sorry for all the questions but in my part of the world if you ask someone 'what would you like to drink' the answer is often 'what have you got'? In other words, there is no point in asking for unrealistic / unavailable items.
Don
