HGLW kitbuild with Deltang rc
ge_rik
1,244
Cheshire
www.riksrailway.blogspot.com
Decided it was about time I built a simple diesel kit and installed basic Deltang rc. Most of the builds on my blog are quite complex by comparison so I thought I'd keep this one simple.
The kit cost around £40, plus the battery, wiring loom and Rx65 receiver (another £50 in total).
https://riksrailway.blogspot.co.uk/2018/04/how-i-constructed-hglw-loco-kit-and.html
Still got to do some more detailing add couplings and a give her a final paint job, but this is the result of one day's work.
Rik
Reactions: 4 users
4,991
Rik
Nice build Rik, like the sound actually as well. Much like a Tram. Perhaps she could be like many modern views of traction and be a Battery Loco as in real Battery Loco, sound would be fine then.
ge_rik
1,244
Cheshire
ge_rik
1,244
Cheshire
She's now emerged from the paint-shop and had a few more details added - couplings (yes, I know LGB couplings look $#!t , but they make shunting a lot easier - and they are comparatively cheap), buffers (courtesy of Binnie Engineering), radiator and grille (you can just make out the vertical tubes of the radiator behind the grille), exhaust pipe (a la Peldon - ie bits of copper tube and plastic rod), hand rails (bent brass rod and a couple of washers) and a driver (Jon's People).
file.php
file.php
file.php
file.php
file.php
Will do a bit more detailing (eg inside the cab), add some nameplates and a number, do some weathering (I don't do ex-works pristine on my railway) and then she can enter service to potter around the sidings at the sawmill.
Rik
Reactions: 5 users
Zerogee
Clencher's Bogleman
1,723
North Essex
Great little build!
As discussed at some length in another thread a couple of weeks back, nothing wrong with using LGB couplers - they may not be particularly attractive, but they WORK, which in my book is the most important thing.....
ge_rik
1,244
Cheshire
Great little build!
Hi Jon
The do sit quite nicely under the Binnie buffers. They don't quite disappear, but they are less prominent.
Rik
ge_rik
1,244
Cheshire
Hi folks
The weekend weather afforded an opportunity to get out into the garden. Thought I'd give HGLW (temporary name) a chance to strut her stuff. Adds an extra dimension to shunting operations at Peckforton station. A few minor tweaks needed - a bit more weight and I need to widen the back-to-backs as she can slip down where the track gauge widens on some points to accommodate the point blades (see if you can spot her doing a neat little curtsey). Otherwise, pleased to see how well she performs.
Rik
Reactions: 1 users
4,991
Hi folks
Rik
Lovely little vid Rik, shows nicely the way that a real railway should run. Note the time taken to just detach a few loaded wagons and attach some empties. The real thing used to do this all the time, now pretty much a historical view of things. Well not quite but nearly. Just so much more interesting than watching them go round and round and round. Though that is ok at times as well.
ge_rik
1,244
Cheshire
Thanks Jon. Having an extra loco at Peckforton certainly adds operational interest - and I'm sure there are prototypical precedents as well. I might even consider using my Simplex as a shunting loco at the copper mine - though I maybe need to add another couple of sidings there to give it something to do.
Rik
4,991
Rik
Not unusual to have an Industrial Pilot at an Industrial Siding that only had a small amount of work to do so no need to beat yourself up about it. Though of course if you desire to add more traffic, who am I to complain? Just thinking about the Cooper Mine you could have Pit Props, explosives, other stores in and perhaps Spoil out in different wagons to somewhere else perhaps for Road Surface Treating or even Block Making another location to think about? Or to your Main Interchange Station.
gregh
1 Nov 2009
3,137
263
Sydney, Australia
www.members.optusnet.com.au
Hi folks
...... Thought I'd give HGLW (temporary name) a chance to strut her stuff......
Rik
It's a little known fact that HGLW was a mythical Norse creature. Supposedly had a steel belly that scraped along the ground causing sparks. But best known for the noxious odours and blue vapours that were emitted from the breathing hole near its head.
o_O :D
ge_rik
1,244
Cheshire
o_O :D
:clap:
Actually, when I type hglw into google it offers me something in Arabic script. Just tried Google Translate and hgl translates from Arabic to mean 'partition'. It auto detects hglw as Welsh which then translates into ........ hglw! So maybe it's a breed of Welsh dragon?
Rik
3,521
So............
Nameplates in Arabic script?? Or 'Idris' (the little dragon from Ivor the Engine!)??
:think::):):)
gregh
1 Nov 2009
3,137
263
Sydney, Australia
:clap:
Rik
Oh I forgot about Welsh. Surely if would be HGGLLW ?
