Hi guys,
As most of you have probably noticed, by big kit from Germany has arrived for the Faur L45H/Lxd2 (http://www.gscalecentral.net/m202013 ).
It is provided with two powered motor bogies. These appear to be custom units using parts from USA trains, and has two trailing leads of fine gauge wire to allow you to wire them together to improve the length of pick ups over the whole diesel. Hence, without stripping down these custom units I guess that means there is no easy provision for DCC.
My basic requirements are simply constant brightness directional lighting.
Is there an easy 'off the shelf' solution to this?
Next I run analog, but want to consider fitting sound.
Is it possible to fit a sound card without spliting these motor units and seperating the pickups from the motor connections? (i.e. just powering the sound chip straight from the track voltage?)
Would a sound card (or chip) have lighting output capability?
I want a diesel hydraulic sound, without all the 'station announcements' and guff you see on the advert or Massoth demo files on their website. How does all that work?
How do you adjust sound volume? Can you do it via a small potentiometer (i.e. without access to a DCC system).
What are my options? Who supplies stuff like this?
I guess the ultimate would be to fit DCC...
I guess a chip with sound built in would then be the best option - and would provide constant 5V output for light sources?
Can these be setup to run on an analog system with sound?
Advice on options would be appreciated
