Er... it stands for Nick The Programmer I've worked in IT all my career, and way back in the 80s my UK company had a US office in Boston, one of the staff there started using the abbreviation NTP when referring to work I was doing for them - and it stuck. I'm still with the same company (the US office is long gone ) and still known as NTP by long-time staff.....Hi Greg and ntpntpntp (waht does ntp mean??)...
Always wondered about that. I was in IT but in my last years was predominantly a Tester so perhaps my handle could be JDTTJDTT.Er... it stands for Nick The Programmer I've worked in IT all my career, and way back in the 80s my UK company had a US office in Boston, one of the staff there started using the abbreviation NTP when referring to work I was doing for them - and it stuck. I'm still with the same company (the US office is long gone ) and still known as NTP by long-time staff.....
Greg - I'm surprised you didn't state your opinion about running LGB or other brand Analog locomotives on DCC current.........you're usually quick to give advice! Since you're an electrical engineer, you have a valid perspective on this question. As I recall your past responses to similar questions on several large scale forums has been, NOT recommended due to likely harm to the motor. As we know, the DCC decoders output PWM current to motors, not DC or DCC current. I'm not an electrical engineer, but exposing a DC designed motor to AC or DCC doesn't seem a good thing to do, and the DC motor is talking back with that nasty hum noise too when using operating it on DCC. Maybe smoking tobacco is a good analogy, it damages your health but won't kill you immediately.Gerard, you have revived an old thread, and there was some good data in the thread and some wrong data.
Address 0 means "pulse stretching" and it was very "rough" on motors, and did cause heating and physical noise.
I would suggest you read up on the subject to get good data. It has NOTHING to do with addressing, but the radical change in the DCC waveform.
Zero Stretching
Zero Stretching is an optional feature of Digital Command Control, allowing operation of a DC–powered locomotive on DCC–powered rails. Also known as 'Zero Bit Stretching' in the DCC specifications and informally referred to as 'Address 00'.dccwiki.com
I think I would be more bothered about damaging an expensive central Station, though I have no grounds whatsoever for this worry having had a Bachmann Shay (as Loco 0) running on a friends line all day back in LGB P equipment days. We knew no better then,It would be an interesting experiment to conduct, using a ‘sacrificial’ g scale type motor. Just leave it connected to a powered up central station, and see what happens.
I’m not offering by the way!
Malcolm
Sammler - Just disconnect your DCC Command Station from your layout and connect a DC Analog Power Supply and Throttle to it and then run your non-DCC locomotives on it. Remove any DCC locomotives from the layout before operating the DC system. This will be your best solution until you convert the rest of your locomotives to DCC. If you have any LGB or Massoth DCC track switch decoders connected to your layout, exposing them to DC current will not harm them.....Massoth confirmed the DC current will not harm them.I've been thinking about using a pre-digital Stainz loco on an LGB digital layout and have read that using locomotives in analogue mode can (in theory) burn out the motor. Has anyone actually damaged an analogue locomotives motor on an MTS digital track?
The MTS instructions say that LGB analogue locomotives work fine on digital track so I thought that all the rumours regarding motor damage might be from other companies products or maybe from users who run smaller scale locomotives with tiny motors.
