Madman
		stevelewis said:Madman said:For those that don't feel like soldering jumper wires across rail joints, for whatever reason. I wonder how much difference in voltage drop there might be between track with soldered jumpers, and track with graphite, or what have you, paste at the rail joints????:thinking:
Some years ago ( Mid 80s) A magazine had an article where this very subject was raised! It was just about the time thst LBG introduced Graphite Paste............
Test were carried out on an established garden line with soldered jumper cables and a line that was simply connected with standard fishplates ( rail joiners)
The voltage drop was found to be very similar, no real advantage was shown from the soldered joint line tests were doen in varying weather conditions ( dry warm days , wet warm days, cold weather etc)
For those who feel they MUST bond their joints, the job can be made a bit simpler ( less soldering ie only 1 not 2 soldering connections per rail length) by adopting a method that some 0 gauge fans use:
A small hole is drilled thro' the "thin part" of the rail section usually half way along its length, thro' this hole a bared cable end is passed and secured by twisting the bared wires UNDER!! the rail, the hole and the twisted cable is then soldered......this makes for a far more secure soldered joint than simply soldering a cable to the rail........
The cable connection is then connected to the next cable on the next rail section and so on & so forth!!
Uses more cable obviously but makes for a secure power transmission system, I personally wouldnt bother having been quite happy with the rail joiners over the years!!
I have used the drilled hole method, although not on all of my track. It does indeed make soldered connection more secure, and it seems to make the solder flow better, than just scarifying the side of the rail with a Dremel tool.
