Bill Barnwell
Just purchased and received a new 82498 3 truck Bachmann 1:20 shay and found the draw bar is installed backwards as the end with the 2 holes is mounted under the main chassis of the engine, it is mounted in the farthest hole which means that it should run tight turns ok but was wondering if these is a mistake or done on purpose as maybe they were having problems of people running the wrong hole and having problems. Another thing I noticed is that on the main frame end the draw bar has a coiled spring on it that is on the up side of the bar and pushes the bar down, and being as the water car part attaches to it and the post with the screw in it isn't too long should the spring be on the under side so that it pushes up on the bar instead of down. Any input would be appreciated as I have contacted Bachmann and haven't heard back from them. Also viewed the DVD and was wonder what every one else uses of lubricants or where to by the Bachmann ones ? Bill
