Nodrog1826
Professional Idiot
I am looking for advice/info. of a suitable lighting decoder, for the fitting of lighting effects to a building, this one...
I am planning to add lights to the underside of the roof overhangs and the interior, probably those flexi led strips that you can cut. to fit.
I have looked at a the TCS FL4 function decoder,
http://www.digitrains.co.uk/ecommer...ction-only/tcs-fl4-function-only-decoder.aspx
but this is a 00 market item, so not sure of any problems in the upper voltage end with Massoth, or any other problems outdoors that may present themselves.
If all else fails I could just go with the led and a battery set up.
