Roger the Dodger
So I'm sitting here with a very nice LGB 22470 rack engine in front of me - and no instructions. Can anyone please tell me how to get at the circuit board to fit a decoder?
I should add that I wrote up how to add an automatic uncoupler to this loco which shows the loco disassembled.
Massoth Automatic Uncoupler - G Scale Central
This exploded parts diagram should help you get started:
https://www.trainli.com/LGB-PDF/LGB Engines/20471-1.pdf
It's for an earlier model but the basic construction hasn't changed.
I used to have one which had a decoder fitted but I had to open it up to add a Massoth S sound decoder, and I don't remember any particular difficulties. You don't need to disassemble the rather intricate rack and adhesion movements which is something of a relief.
I do not see a pic!
But I would assume from your description that it has a 10pin DCC interface (the other 3 are used by the blanking plate only). If you dont want sound then a Massoth XL would be best (especially if you want to actually use it on a rack) with a 10 pin interface cable.
