D
Deleted member 1986
Guest
DiMAX 1202B Digital Booster
The DiMAX 1202B Digital Booster is a powerful state-of-the-art Booster.
Two seperate power outlets feature 6 amps each offering enough power for two seperate track sections on a model train layout. If the 6 amps per output are not sufficient, both single outputs may be combined to one single powerful 12 amp output. The track voltage is adjusted in 5 steps: 14, 16, 18, 20 and 22 Volt.
An adequate power supply is required with 18-24 Volt (DC) and 12 amps minimum, e.g. the DiMAX 1200T Power Supply (8135501) with a maximum of 15 amps.
Besides the typical booster bus connector for DiMAX- and LGB-components it also offers the common C-D-E-connectors. This makes the Booster compatible with most of the known Central Stations.
It can be used independently of the data format and may also be used with Motorola, Selectrix, etc. in addition to NMRA / DCC.
In addition to the normal booster mode, a brake booster function with active function command transmission, as well as RailCom and MfX are also supported.
An additional MfX function module (not yet available) must be retrofitted for MfX operation.
All settings are configured with easy-to-use buttons on the front of the booster. A clear LED display shows the current settings as well as the operating state.
