Being relatively new to this..
I think it would be a good idea if there was a 'sticky' in this section with all those things it would be good to know when starting out, or adding to your railway..
I am thinking of things like dimensions. - Not just radii of the differing curves, but suggested inter-track spacing (or what it should work-out to with differing radii curves). Clearances, both to the outside of a running line as well as loading gauge / minimum clearance under bridges. Gradients, both plain-track and rack. Thoughts / perceived wisdom on super-elevation on curves. tolerances for out of level (that work!). Possibly back-to-back dimensions for different makes of stock.
Maybe ways of doing things that a beginner would not know, or think of, to make certain jobs that bit easier.
Thinking of a couple of sides of A4 with 'the numbers' on, then a series of sensible posts on the way things can be done which work, and allow trains to run without hitting each other, or the scenery.
The collective knowledge of those on the Forum collected in one place would be a phenomenal resource.
It is all probably 'somewhere' on here anyway.. it is just finding it that is the problem!
