nicebutdim
Hi everyone. As some of you know I made a rc points control system last year http://www.gscalecentral.net/tm?m=168646&high=rc+points < Link To http://www.gscalecentral....646&high=rc+points Now has come the time for some modification again. What I need is an led on the control box that is controlled from the relay box in the shed, it is as simple as that at the moment. One of the latched relays will need to be connected to a simple single channel transmitter that would send a signal to a receiver in my hand held control box and hold an led either on or off depending on the relays state, basically making the control box bi-directional with communication. Trying to find such a simple transmitter/receiver pair is proving quite hard, the nearest I can find is this http://www.conrad-uk.com/ce/en/product/190939?WT.mc_id=googlebase?insert=8V is it ok for my requirement? Does anyone know anywhere I can get a simple 1 channel tx/rx setup that basically just works to relay a logic I/O signal?
Many thanks,
Tim
Many thanks,
Tim
