I've added Steve's text into this thread to make it easier for me to link directly from the complilation, thanks Steve.
     Paul
     RE  DECODER  FITING  IN  OLDER  3  WIRE  SYSTEM  GEARBOX  LOCOS
     I have  completed installation  of  a  Massoth XL decoder  in  my  LGB QM  ALCO  Diesel  loco.
     I devised  what  I  think  is   a simple  method of  overcoming  the 'problem' of  the   common WHITE  cable on one  side  of  the  gearboxes...........this  cable  both  supplies  picked up power to loco's   ANALOGUE PCB  and  and is  also  the  same connector  for  one  side  of  the  motor  supply, so  therefore  in DCC mode  this  is  a  no go  situation!!
      This motor  feed  and  pickup  MUST  be seperated!!
     I achieved this  quite  simply!
     I insulated with  around 10mm of  plastic tape  the metal strip  which connects  electrically  the skate &  carbon wheel pickups on  the gearbox side which has  the  SINGLE white cable. the small piece of insulation is positioned  to isolate the PIN to which the  single WHITE cable, so now  the  PIN only supplies power to  the motor contact, and  the  white  cable  becomes a motor feed  from  the  DECODER
     I soldered  a  NEW lead to  the BRASS  skate holder on the  G box,   this  lead  now  supplies  track power to  one  decoder input,
     (it  is  nescessary to drill a couple of  small holes in  the  gearbox housing  to  route  the NEW cable inside  the  loco to  the  decoder,)
     So from  then in its  just  normal hard wired  decoder  installation  using  the  3  original LGB  cables  and  the NEW cable for decoder input and motor  feed,  remembering  of  course  its  a  bogie  loco  so it  all has  to  be  done  twice!!
     Lghts  all wired  to  decoder  and  original  PCB  removed,  it  all worked  first  time.
     I  forgot  to  take  phots,  but  I will prob be  doing another  and  will remeber  to  do  so  then!
