DavidT said:
Thanks guys. Hi Rik, It may help to disable 'tx change', easiest with paperclip change method. This would remove one possible cause. You would need the Selecta 2-flash option http://www.deltang.co.uk/paperclip-v611.htm
Regards, David.
Thanks David. Very helpful
I see from another thread that the rx status LED can be fed to an LED output such as one of the direction lights, and this is then overridden once the rx finds the tx signal.
Just wondered what happens if the tx is then switched off, would it continue with its direction setting or if stationary, would it eventually show the rx status? Although there is a timed SLEEP setting for the rx, I would find it useful to have some sort of LED indicator reminding me that the loco is still switched on if I forget to switch it off.
Really like the feature whereby the LED flashes the remaining battery voltage BTW
Rik
