Diesel2000
Hi Folks,
I just acquired a CS3 and 60195 power pack (the USA equivalent to L51095) for 1 gauge/LGB. I've been setting up locos and run into an issue where I have Massoth pulsed smoke generators 8415001 fitted. Initially when using M4/MFX for ESU 5 XL decoders to register on the CS3 the smoke units came on as soon as power was applied and could not be controlled. I realized since the MPSGs are DCC decoders I'd have to set up those locos under DCC protocol in the CS3 and wont be able to use MFX. On DCC they dont respond to F keys and dont come on at all. I verified these are all working properly on my Massoth 1210z system. I fiddled with some settings and they did start working briefly, but after restart of the system I'm back to them not responding.
I have the CS3 set for the L51095 power pack, but dont have an RRamp meter to measure voltage at the rails. The Massoth pulsed smoke generators require 18V minimum, so I was initially wondering if that was the issue and they were getting less after typical decoder voltage loss, but if they came on under MFX protocol then I'm not sure what the issue could be.
Anyone else using a CS3 and these smoke generators in their locos?
