[quote author=supagav link=topic=299194.msg320408#msg320408 date=1404483890]
What have you guys used for live frog applications? With an EPL point motor?
Neil: How did you use the microswitch you mention? Did you open up the LGB supplementary switch and replace the components inside? What`s the bet way to approach this? Also would you have any pictures showing the install please?
[/quote]
I didn`t open up the LGB supplementary switch as the microswitch fitted by LGB is the highest current rating of its size that I could find. Also my application doesn`t use an LGB point motor, it`s triggered by a pin soldered to one of the blades. You may wish to arrange it to be triggered by the other side of the blade tie bar to that operated by the point motor. However as you already have the LGB switches installed I`d be tempted to use them to operate automotive relay coils with their contacts switching the frog power.
Images of the relatively crude prototype.
Incidentally the LGB microswitches may be economically repaired using the original spec. Cherry microswitches ( one each DG13-B2LA and DG13-B3LA) from Rapid electronics, their part numbers 50-2648 and 50-1146. http://www.rapidonline.com/Design-Technology/Cherry-Sub-Subminiature-Microswitches-DG1-Series-520206
