Code 250 points
Cyclone
I could do with a couple of small radius points for sidings. (45mm)
Peco do the 4 ft ones but these are just a bit too long, so what else is out there?
Tenmile do one but they are £75! Bit much for sidings that are more for aesthetics than function.
Ive looked at the self build Peco stuff but no idea how easy they are to make and if I need a railbender?
Any info? Ta Ed
Not that I've ever tried it as I'm 98% Code 332 LGB.
But you could cut up a Peco ST 905 curve and a ST 902 straight for a home made point? You would then already have the rail bent to the correct radius for a 600mm (2 ft) and essentially the template/pattern.
By using the new IL 920/921/922/923 parts, you could build a point to suit.
The only other way I can think of is to use an LGB/ART/etc R1 point and use the Peco SL 912 rail joiners that connect their code 250 track to code 332 rail. I know of one Norfolk G scaler who has done so, albeit with Peco Points to LGB track....
