I want to set up a cable car or arial tram. It will be very simple, with a single gondola moving back and forth along a cable. I was sketching some circuits with two DPDT switches that the gondola would trip as it reached the end. However, on paper it does not work, since the switches, once tripped, will remain in that position.
Then I thought of using a relay, controlled by two SPDT switches. But alas, the same situation. Once the gondola reaches the end and trips a switch, that switch can never be switched back to it's original postion. Below is the sketched circuit for the relay. But I don't see how this circuit would work. The relay has a DPDT switch that can change the polarity of the cable car motor.
http://1stclass.mylargescale.com/madman/HOW TO/relay.png
