Having changed the numbers allocated to some switches, I wish to reprogrammed three different switch routes. Can I delete the current programmed routes, if so how please.
Hi Greg,Of the LGB central stations, I, II, and III, I presume you are using III....
I have tried to update the existing routes, they only need small changes, but as you say it is an opaque process, I have failed so far!Noting from a long while back how fiendishly un-intuitive LGB point routing was to input, would you be better/is it possible updating existing routes?
That’s what I would like to do, but don’t know how to delete the existing ones.Ahh, you are using MTS II, wow, I've never programmed routes, I would delete them and then start over, but I'm no expert in this hardware.
