Busch 18v street lights
Kevin
I've another plea for help please!
I recently bought some second hand Busch street lights (model number 8621, green, about 8 3/4 inch tall) The box suggests that they are in two parts. However, I can't see how to access the screw in bulb and, as a couple of them light up intermittently, I need to tighten the bulb. Does anyone else have these and know how to get to the bulb?
the top bit, ie the glazzed section, unscrews off the pole...
Wow, I see what you mean; delicate or what. I was afraid turning the top.
Are they standard bulbs or only obtainable from Busch or their Suppliers?
Thanks everyone for the help and advice; very much appreciated.
What a great source of information this forum is :thumbup:
Hi Kevin
Be very CAREFULL when you unscrew the top, especially if they are used
put a bit of thin oil or a tiny bit of wd40 on the join about 1/2 hour before you try, then clean of as soon as apart.
(dont ask how i found that out)
Hi Kevin
Have 4 Busch street lights on my station i too have broken the posts undoing the top to change the bulb you can see in the pic that they have bent over when the glue was setting .
Kevin said:
Thanks Rob, excellent advice I will certainly take on board. They certainly are a tight fit!
I spoiled 2 of them before i finally sat down and thought it through,
Also when i put them back together i put some silicon lube/polish on the threads (got a spray can of the guys who put after market sun roof's in cars) works a treat, but not sure where you can get it from ???
One small can would do about 300 lights as far as i can tell.
