idlemarvel
Neither idle nor a marvel
I just installed a “Weichensignale” Wn 1/Wn 2 mechanical point signal on my indoor layout, a kit from Bertram Heyn
https://modell-werkstatt.de/
I have had a few of his kits/models over the years and found them to be very good, realistic, to scale (IIm) and well engineered. The point signal is no exception. They can be turned by a standard LGB or PIKO point motor. There are left hand and right hand versions, and a choice of bases so you can operate them with a motor, or manually with a point lever, available separately. I got a left hand model with base to operate with a point motor, part numbers 5911 and 5918.
https://modell-werkstatt.de/turnout-point-light-left
https://modell-werkstatt.de/adapter-plate-for-switchpoint-light-power-unit
The point signal comes as a brass kit. It is quite easy to assemble. The instructions are in German. The nuts and bolts are quite small and it would be handy to have a miniature spanner or similar but I managed with flat nosed pliers. The vertical rotating post is held in place on a brass baseplate using two locking nuts. Assemble this before you bolt the brass base plate onto the plastic base. It’s a bit tricky getting the right tightness to allow the post to rotate freely without wobbling too much. The post as supplied is the “tall” version where any wobble is very noticeable (top picture). You can cut the brass post down with a fine hacksaw to “standard” height which is what I did.
The post is hollow so you can thread a cable through to fit a light if you wish. There is translucent plastic inside the brass light box which is too narrow for a standard LGB bulb so you would need a small bulb or LED. (Heyn does one, part number 5913.) They can be painted with standard enamel paints.
I also have his manual point lever with weight (part number 5902). This comes ready assembled in plain brass with a plastic base.
https://modell-werkstatt.de/turnout-lever-local-railway-for-lgb-turnout-small-distance-2
(Before anyone says it, yes the weight should have white facing down when the point is set to turnout.)
I am very pleased with both items. They are more expensive (about €20 a piece) than the LGB or PIKO weichenlaterne but far more realistic IMO.
