Gardenbahner
That looks like a Peco Spring you have added in Pic 4, nice idea.
It's actually a PIKO point. Theirs have springs as well.
You bought a can of air?In the last picture you will see a can of "air duster"
50/50 Water External PVA and a little washing up liquid will hold it all in fine, Pidgeons tend to nick the stuff for their Crop and of course any livestock will dislodge it when loose also rain. But do the glue at the beginning of a warm day otherwise it is likely to not dry properly and also give a good saoking with a small spray with another drop or two of Washing Up Liquid to help the glue get in place prior to applying the glue. I use a Pint or thereabouts old Glue Container to apply the glue. Keep well clear of moving things by careful application in these area’s, also some Oil will stop humming up moving parts.OK, now I have my track laid, and it appears to be accepted by my engines. As I have included parts that are floating on the brickwork, is there any ideas on how to ballast it all without compromising the flexibility of the track and without it all immediately disappearing? Would soaking it in diluted PVA work, or am I worrying too much?
What ratio of water to the quickcrete adhesive do you use?I’ve been ballasting using chicken grit for a while. You have to be careful as some grits use oyster shells which are a bit white for me. I’ve used bags from farm supply stores, but this is from Amazon. It comes in the bags shown and they deliver it (free with Prime), so it’s convenient. I flood it with diluted adhesive. I’ve used external wood glue which has worked well, but now use this concrete adhesive.
Some of the photos show recently ballasted track, but the older ones have been down over a year and survived summer irrigation sprinklers, storms, changes in temperature, humidity and Hurricane Michael last year!
Strangely, some lasts for years, and other bits wash out quite fast. Doesn’t appear to be any obvious reasons for the difference.
View media item 3744View media item 3742View media item 3740View media item 3738View media item 3739View media item 3743
I started off at a 3 water to 1 adhesive. That worked in some places but not in others. I changed to 2 water/1 Adhesive, which was pretty consistantly good, but recently I’ve gone 50/50 and that appears to be perfect! As a test i also used a brushed layer neat onto a concrete block, stuck the track on that and then sprinkled ballast. That has been outside in all weathers and a hurricane and has remained firm. To be honest, you’d need to experiment with what works with your humidity, temperature and rainfall. It’s not an exact science!What ratio of water to the quickcrete adhesive do you use?
great thank you! What do you use to apply it? Do you just paint it on or do you put it in a spray bottle or something?I started off at a 3 water to 1 adhesive. That worked in some places but not in others. I changed to 2 water/1 Adhesive, which was pretty consistantly good, but recently I’ve gone 50/50 and that appears to be perfect! As a test i also used a brushed layer neat onto a concrete block, stuck the track on that and then sprinkled ballast. That has been outside in all weathers and a hurricane and has remained firm. To be honest, you’d need to experiment with what works with your humidity, temperature and rainfall. It’s not an exact science!
I have some contact lens solution bottles which I open up the dispensing hole. They’re sort of squeeze bottles, so i can gently flood the ballast in a relatively controlled manner. It does need to be flooded so that all the ballast sticks to itself. Seems to work. BTW, I don’t have powered track, so not too worried about getting the grunge on the track. I do wipe it of the rail head with a damp cloth though.great thank you! What do you use to apply it? Do you just paint it on or do you put it in a spray bottle or something?
