Beddhist
Motorcycle travel, trains
This is a first for me. I have never worked with any of the components.
To start with, I dismantled most of the truck to fix the known gear box problem, as per http://www.girr.org/girr/tips/tips8/bachmann_railtruck_tips.html#gearbox There is play in all the drivetrain components, so I wonder whether the diff will cause problems in the future. Lots of loose screws in the chassis were tightened.
Here is the chassis with all the gadgets that must be installed:
There is an Airwire Convrtr, a Zimo MX645 with the Galloping Goose sound preloaded and an ESU speaker. The battery is only for testing and will be replaced by something more compact later.
First step is to lose the circuit board. I simply cut off all the wires. I cut the pickup wires to the rear wheels flush with the deck. The speaker will probably sit over the slots in the centre, but there are some burrs from manufacture. 4 screws and the rear axle comes off, I then removed the pickups and everything that went with it. The burrs could now be removed with a sharp knife, so they won`t interfere with the speaker.
Next was a lot of wire stripping and soldering, a process made a little difficult because of my poor eye sight at close range, plus my fingers are not the most nimble. At this stage I didn`t wire the lights, as I don`t have any resistors on hand. After triple-checking all my connections I connected the battery and fired up the Tx. Result:
[youtube]http://www.youtube.com/watch?v=0DOo88okj6o[/youtube]
Hooray, no magic smoke and it works at the first try. First impressions: this is hard to control! Most of the time when I hit the stop button it just keeps going. Most of the time it ran off the end of the track. Sometimes pressing one function key activates the next numbered function. Most annoyingly, after pressing a function key you have to wait several secs before you can use another key. If you don`t it is ignored. At slow speed it runs jerkily. I don`t know whether this might improve over time.
Next is wiring the lights and then installing it all permanently, as well as re-assembling the truck.
Regards,
Peter.
Regards,
Peter.
